Hopefully buildzoid or someone can do a breakdown and clarify things. Or perhaps Asus can come out with more info explaining what is happening.
I think Anan asked Asus, and are waiting on more info. Hopefully soon.
There's a driver IC in each of the powerstages and each has a high side, low side, and inductor. Additionally the implementation likely has tri-state PWM support (high/low/off) and current detection such that phases are turned off completely when unused. Given the efficiency and shoot through protection of the SiC639 powerstages it really is a nitpick.
Tech Yes City tested the Hero and had it was cooler than the z390 Taichi that uses doublers with 10x TI NexFETs, so the implementation acts more like an 8 phase.
On M10H/C/F (Maximus X Hero/Code/Formula), there are 4x PWM signals driving 8x power stages (package with driver, high-side and low-side MOSFET). A doubler will interleave a single PWM signal into two power stages, alternatively switching between them. As long as you still have one driver per power stage, the output current capability is roughly the same in both scenarios. What you should watch out for are VRMs where a single driver is used for multiple high-side/low-side MOSFET pairs, which severely increases switching losses.
When using a doubler, much of the behavior is the same as a real 8-phase PWM solution. At any given time only a single power stage will be activated which has benefits like lower input and output ripple. That allows you to use fewer components for input/output filtering. Depending on the specific doubler used, it may still be possible to do current balancing which allows for better thermals.
The primary benefit of using double components (like the Maximus XI Hero/Code/Formula) is faster response time. When you use a doubler, the PWM signal has to go through an additional IC which slightly delays the signal. For example IR3599 has a typical propagation delay of ~10-30 ns.
I've been reading those threads as well. All good info. I've had the formula and a 9900k since release and it is a non issue. I'm just following along now because I'm curious to know what the specs are and to see if Asus provide a response.Here's some info which was dug up on overclock.net courtesy of some VRM experts there. Basically, it uses a doubled 4 phase as opposed to an 8 phase using doublers as the Maximus X did. Here are some technical details:
Aside from that it would be interesting to know how one VRM implementation compares to the next in terms of efficiency.
Formula has 8 + 4.Interesting to see how your single 8 pin does vs dual 8/ 8+4 pin since in theory voltage is split more evenly etc
Every board vendor, recommending changing thermal pads , still need to track down Asus pad details but I know they all should be 2 w/km and under (super cheap stuff)
Formula has 8 + 4.
Ah that makes sense. I was going to get the z370 series but I survived the wait and went with z390.apologies, ,misread that as having the older z370 and using 9900k .
current z390 seem to be doing well with heat at both software and thermal cam level
I'm glad i did. I love the way it looks.
Agreed.just a shame z370 came to be and was a rush by intel . z390 was already on the board to replace z370 but 8 core came as a blessing , though now z390 adds to the 14nm production nightmare![]()
The Code and Formula power stages look very similar to me from the photos I have seen. Looking at the PCB pics for the Hero I can see some differences between it and the Code / Formula around the VRM area, but whether they are significant, or even related to the power delivery, I don't know.I have a CODE on order but no idea of a delivery date, is there anypoint waiting around or do I just chuck some extra cash in and get the Formula (with no intention of watercooling) or downgrade to the Hero (WIFI)? The reviews don't some to be clear if the formula VRM set up is any different?
NP. I don't know how it is in normal operation, but the video below was done with a Z390 Hero iirc. It was able to hit 6ghz on LN2 and was only restricted by the board not being insulated and the lack of a BIOS that allowed for extreme temperatures. The board wasn't properly prepared because he was originally using a z390 Taichi, but that died due to condensation so the Hero BIOS and board was an on the spot thing.Thanks for that, will wait for some reviews of the code to appear before deciding.
That's a valid point.Unless all the cool looking plastic makes the board run hotter.....
Gene is up for pre order. No thanks. The hero is a smarter buy.
So much for it being in the price range we had talked about @8 Pack
