It's arguably the best performing card around the £350 budget, but it is also around 10% slower than the Vega64.Powercolor Vega 56 a worthy card?
AMD's 590 is due to be announced soon, it'll land around the 1080 performance range too.
Alternatively an RX 580 8G at £200 is the best value proposition of them all!
The Vega56 should be able to maintain a solid 60fps+ in most games once overclocked, but for 4K it would definitely be falling short. For my overclocked Vega64, I found that it can maintain 45fps+ at 3200x1600 in Monster Hunter World, but it does fall short for 3840x2160 unless I turn the graphic settings way down (which I think look far worse than 3200x1600 with high graphic settings).
10% if you already managing 60fps+ it probably won't make much of a difference, but if using the Monster Hunter World example I mentioned as above, the difference between the overclocked Vega64 vs the overclocked Vega56 would be something like minimum 45fps vs 40fps...which the 5fps different can be quite a noticeable difference in perceived smoothness.
At the end of the day, it would be down to you to decide if you are willing to spend the extra as a long term investment for the return in better performance in gaming.
For what its worth, I got rid of my GTX 1080 and got a Vega 64 and i'd never look back.
If you have a freesync monitor its a no brainer. The reality is that "unleashed" i.e framerates in the tripple digits the GTX 1080 may perform slightly better and draw less power but within the actual usable freesync ranges i.e 60 -120 odd fps they are pretty much identical with the Vega often offering up a bit more consistent experience.
Vega is a lot more tweakable but has maybe less out of the box performance than the offerings from nvidia.
All depends on you and of course your use case, but like I said, the combo of Freesync and Radeon Chill is great and as a whole the Radeon ecosystem is nice to use
That's Navi, the 590 is just another clock bumped 480, like the 580 was
It is 10-12% faster than RX 580.
Estimated cost £280-£300, VEGA 56 is still quite a bit faster and at £350 better value for the performance it offers.
Just had the same dilemma, but I added the slightly more expensive Vega64, 1080 and 2070 into the mix too, I have been looking at benchmarks for ages, months in fact then I decided to wait and see what the 2070 was like.
I have just ordered the 1070ti.. I’m expecting a good performance increase over my exsisting r9-290.
I wanted the Vega64 ideally,Leaning in the same direction as yourself, will make my decision soon... catching up on some reviews etc.
will do, I’m gaming at 1080p 60hz, but mostly on a Oculus Rift playing VR.I have the R290 as well and been looking at reviews for 1070ti it something else.
Let me know how if you can crank up games to max on 1080p Res.
It will breeze through 1080p. Everything bar Ark Survival on Ultra high.I have the R290 as well and been looking at reviews for 1070ti it something else.
Now we just need the wink... Dissapointed if they are going to hike the price that high for that size performance bump.
Maybe compared to the competition, but compared to the age of the cards... not so much.An RX 580 8G at £200 or an RX 570 8G at £150 are simply epic bargains and just been done to clear excess inventory.
