If you use HWInfo, whats the voltage on the HBM?
GPU memory voltage (MVDDC) is listed as 1.250 V.
Thats why. Keep it to 1050 if you can or 1000 worst case.
I have no idea if you can flash this specific card it with Vega 64 bios.
If so, you would be able to overclock better.
The Voltage for HBM in Wattman is nothing to do with actual HBM voltage. It acts like a floor or minimum core voltage for that particular power state.Wattman has it listed as 950 though. Is that better? The voltages on HWInfo don't seem to change whether the card is working or not.
Should have dual BIOS with a switch on the card. Only one should be flashable (position closest to DP/HDMI connectors) so bricking the card is incredibly hard.I don't think I'll risk a different card's BIOS just yet, as this card only arrived yesterday. I don't want to brick it.
This shows you could probably set P7 higher. For best gaming performance I disable all Power States below P7 core and P3 HBM so there's no stutter when switching power state in game. One thing to try is unlock the Power (using a PP table registry mod) and then control the performance via the voltage. Usually this means setting HBM to a known good frequency (takes some testing to find), the P7 state to 1750MHz and Power to 200% using the PP Table mod, then incrementally increasing the P7 voltage until you find the max capability of the cooler or crashes when stress testing.I haven't overclocked anything yet! I just added five percent to the clock speed and it's now solidly boosting to just over 1600 mhz !
Got the cooler ordered should be with me in time for Saturday. Will flash the LC bios on and see what how it goes.
Anyone playing much black ops 4 blackout?
At 1440p and high settings I can dip to 40s in FPS. Also a crazy amount of crashes and even blue screen
Vega 64 seems so much fun to tweak about with. I'm so tempted to ditch the nVidia ecosystem (gsync + GPU) and head over to AMD. Vega 64 seems able to run everything well until 7nm/Navi hits us.
nVidia prices area a very bitter pill to swallow at the moment, but I get the feeling these kind of prices are here to stay and 7nm won't change a thing.
you star......the strix is really my last hope for a vega for now (without a whole load of flaff) i think i can just about squeeze a 300mm long card in without redoing my cpu loop
- I won't be moving the card etc - but relying on the warranty Thanks. Happy with the card though looks amazing
cheers fella. stuck on phone at the mo so a tad difficult to see but it looks to be about just shy of 30cm?snip
I don't think Navi's going to have a ray-tracing solution like Nvidia's 2000 series has so it should mean the cards are a lot cheaper to develop & make, That should mean cheaper cards from AMD, If they try to do the same thing with prices I'll stick with my Vega card for as long as possible. I'm currently testing the water with a PS4 and the Xim mouse and keyboard adapter so if I can get on with that I might grab a PS5 instead of focusing on PC gaming.
One big hurdle with that is whether I can run my PS4 games on the PS5. Now the consoles are based on a PC style design there shouldn't be an issue with running the games unless Sony & Microsoft decide to block it.
I think I will be happy with results. 1550mhz is about the maximum my card can hold right now and often at higher resolution it's lower for some reason. I am confident getting the LC bios should fix that. Plus it should be quieterNice, you'll have fun with that. You'll see a good 5-8fps maximum improvement, but your hbm should be able to clock a little further, due to the heat reduction. Also if it stays below 50c you won't get the 15-25mhz clock reduction. And you'll be so happy with the quietness coming from the previous peasant cooler.
Do you use 18.10.2 drivers? Can you show us your settings?
You need latest for this game.Used various drivers, back as far as 18.5, 18.9.3 and the latest. Will post later when I can
