I have and own itHad my 100-400 on all day again today, something I couldn’t do with the supplied one. Yes the peak design isn’t cheap but no more bad neck / back for me.
Has anyone used the sigma art 35mm F1.4?
What do you think of it? I’ve been offered one for a good priceI have and own it
Nice one I’ll go get it. It’s the e mount versionExcellent .I have the native e mount version Previously had the Canon mounted on a adapter
I had my LED lamp on while taking the photoYou need to correct your White Balance![]()
I had my LED lamp on while taking the photoBut i'll look at it anyway now you have mentioned it.
Don't give me excuses Sargent ! Now drop and give me 50.
It was set to 5500K in manual mode, is AWB better?
Seen that button but never clicked on it
Now it seems too white, will take some getting used to!
I'm an absolute amateur in LRToo much green, move the Temp/Tint around until you get something that looks right.
I'm an absolute amateur in LRMay as well be bashing the mouse and keyboard and hope for the best
or use a plugin hehe1 - move the sliders until it looks right or look good.
2 - don't like it, go the opposite way.
Just use the Auto function to start with, it produces good base results that you can then tweak. There is no excuse for notlearning the basics of lightroom when you can simply search for and use some very straightforward Youtube tutorials.I'm an absolute amateur in LRMay as well be bashing the mouse and keyboard and hope for the best
