I'll take one please?Ta muchly. Wouldn't mind trying before buying
Origin user below (just created it - never used origin before):
DarrenStanners
I’ll try to get on 8ish to send to you
DarrenStanners
Cheers.I’ll try to get on 8ish to send to you
Cheers.
Sits patiently looking out of a dark window into the abyss....waiting......
If I may could I get one please. Kruxxie1putting the kids to bed mate hold on. edit sent. 2 more if anyone wants one??
So is this included as part of origin access? On release day if I subscribe I can play it for a year for £20?
Thanks very much!putting the kids to bed mate hold on. edit sent. 2 more if anyone wants one??
PC is the only way to play FPS
Sorry! Uplay is with the 1, you are right it is kruxxie on eano user found dude. wanna check your spelling?
edit are you just Kruxxie?
I've gone from a solid 60fps to 40-50fps since the update a couple of days back - anyone know a solution of what's caused it?
Sorry! Uplay is with the 1, you are right it is kruxxie on ea![]()
