YesAbout time you changed your bike, isn’t it?![]()
I don't have my iPhone X anymore and the camera on my new phone is shocking so i can't use that. Last year me and my dad went on the last Sunday and it was empty, took us less than 2 hours to look around everything including the stunt show! You going this year?It’s a beauty, for sure. I’m waiting for the new XR they’ll make off the back of it.
Back on topic, I didn’t bother with my camera for the last bike show I went to, as it was just so crowded. I just took my phone.
I would never take a prime to a motorsports event when you are standing in a crowd, it is completely impractical unless you are in the special journalist areas where they want to capture a specific spot.I'm going to motorcycle live on Saturday, do you think the 28mm will be wide enough? I have a feeling it's going to be crowded as it's the penultimate day and I may not be able to get far enough back for some shots without having people in the frame.
Was looking for a cheap wider lens that will do me for the day but equally as sharp as the Tamron, only I don't know what to choose? Any tips?
If I take pictures of my bike I need to be around 4ft away to get the bike in the frame @ 28mm, I may not have that room at the show![]()
Anyone have the Sony 24mm 1.4 and share some thoughts on it ?
Mainly shoot events / parties
It's all indoors and everything is fixed so nothing moving etc, just thought maybe with it being crowded then the 28mm might not be wide enough if I can't get far enough back to get the whole bike in the frame.I would never take a prime to a motorsports event when you are standing in a crowd, it is completely impractical unless you are in the special journalist areas where they want to capture a specific spot.
A 70-200mm is ideal, but the Tamron 28-75mm would also be a good option.
Have any of you had issues with the SanDisk extreme pro?
I’ve had what look like two different batches, the ones that are shrink wrap sealed inside work fine, the ones that are loose in a tray are the ones the camera won’t recognise.
I went in to my local camera shop last Friday.. £200 off the A7III but for some reason I bottled it.. I was kinda put off when she said about the exposed sensor and said maybe wait for the A7SIII?
Been eyeing up the Sony 24mm 1.4, can get it for £1299 but not sure I can justify it just yet.
not as good as the 100-400Once you do, you will love it. Best Lens Sony has made IMO so far
