Ordered the Evolv X in Gunmetal yesterday after Chug put a discount on them, should be here todaythen to work out what I need to swap my parts and loop over and still make it work with 2 rads.
@ChugNorris - so there was a black Friday discount!Absolutely zero chance.
lol@ChugNorris - so there was a black Friday discount!lol
Also I still can't work out which halo lux I need digital or non-digital. If I want to plug them into the phanteks case/ motherboard to control them is it the digital ones?
Nope only digital ones work(3pin) as I had to send the others back![]()
I believe both would work, but Digital is the more feature rich.
Thanks - my motherboard only has 4 pin 12v so I was looking to ensure comparability with next one. Will be using case for foreseeable so digital it is then.Depends on the motherboard though, if purely for the Evolv X then yes, digital only.
Anyone managed to get the new Z390 Maximus Extreme to fit this case? (Evolv X) , I have the Z390 Maximus Formula and that fits fine but the Extreme will not fit seems the standoffs are too short.![]()
did you have any trouble fitting the maximus formula into this? what did you do about the middle screw that you cant get in (due to the shield covering it)
I left the standoff in place but didn't fit the screw.
The Maximus Formula fitted the Evolv X fine.
Did you have to use any force to align the screws or did they all fit perfectly?
