- 4 Nov 2013
I don't have any issues with mine chill is set to min/max 130fps
Game runs at 130fps all the time.
Can you make sure you selecting the correct exe file.
Try selecting enhanced sync global not by profile .
Thanks for your reply.
During a match, yes, I hit 143 fps (my fps max) most of the time.
But when I pause during a match, it drops to around 72.
If I go to replay -> change it to the 360 degree mode, it locks at 30fps, same for a few match opening cut scene, for example when the players are shaking hands.
Do you have these problems?
