The AMD Driver Thread
4 Nov 2013
I don't have any issues with mine chill is set to min/max 130fps
Game runs at 130fps all the time.
Can you make sure you selecting the correct exe file.
Try selecting enhanced sync global not by profile .
Thanks for your reply.
During a match, yes, I hit 143 fps (my fps max) most of the time.
But when I pause during a match, it drops to around 72.
If I go to replay -> change it to the 360 degree mode, it locks at 30fps, same for a few match opening cut scene, for example when the players are shaking hands.
Do you have these problems?
25 Nov 2011
The KOP
I do get 72fps in the menu but that is it. The rest is 130fps
Do you have directx 12 enabled? Try dx11 if you do.
25 Nov 2011
The KOP
I am on dx11 so dont know what to do...
this 30fps lock is really annoying...
Can understand I had an issue like this with FIFA 17, give this a try might seem crazy but set the game settings to 30fps lock. Does turning off Freesync fix the fps drop to 30fps?
On FIFA 16 if I had Freesync enabled I set the game to 30fps and it would run at 72fps locked.
I didn't buy FIFA 18 so not sure if anything changed there but I am running this years FIFA fine.
6 Dec 2013
Nottingham
on 18.11.2, does anybody else using a superwide occasionally loose the superwide resolution after boot? i have to restart to get it back, just randomly started happening. LG 29WK500 @ 2560 x 1080. cable isnt the issue ive tested it at 4k with no issue.
25 Nov 2011
The KOP
Must be some big features coming to get its own event :D Did the previous years get closed door events?
Let the fun begin! 70 minutes until the first batch of media get to experience the future. @Radeon @AMD #SeoulROCKS
https://twitter.com/CatalystMaker/status/1067219511676301312?s=19
Hype
6 Dec 2013
Nottingham
reinstalling the monitor driver seems to have fixed the issue for anybody else that see's the same or a similar issue.
27 Jun 2008
I've had my VEGA 56 for just over a week now and I've been having issues with bright colours appearing after display adjustments (notable during a resolution change). I can't capture it with a screenshot as it appears to be coming from whatever processes the display output and now at a lower internal level. It starts with a random solid colour (usually a bright pink or orange) and then I get an saturated image with a animated noisy overlay like this PS re-creation:-
Using 18.11.1. I am also using a display port to DVI adapter so is it possible that is the cause of it?
25 Nov 2011
The KOP
Radeon Software Adrenalin Edition 18.12.1 Highlights
Support For
  • Just Cause™ 4
Known Issues
  • Some systems running multiple displays may experience mouse lag when at least one display is enabled but powered off.
  • Assassin’s Creed™: Odyssey may experience a game crash at certain locations of the game on Windows®7 enabled system configurations.
Package Contents
The Radeon Software Adrenalin Edition 18.12.1 installation package contains the following:
  • Radeon Software Adrenalin Edition 18.12.1 Driver Version 18.40.11.09 (Windows Driver Store Version 25.20.14011.9004)
https://www.amd.com/en/support/kb/release-notes/rn-rad-win-18-12-1?sf203228033=1
