Did you fix this?
May be similar to this one: http://www.ft86club.com/forums/showthread.php?t=125947
Yea there was a leaf stuck in there.
Did you fix this?
You can adjust that can't you? I know you can on the MY17 manual. I set it at 7000 to give me time to change!I managed to make the rev limiter light come on today. Didn't think that was possible in normal mode in the automatic.
Do you use air con?
Could be the cabin filters or damp within the car. Should really run the aircon often/all the time, especially if you have the R1234yf gas (check under bonnet for gas sticker).
I've currently got new car smell due to the gunk they use to re-seal the doors.
The vents probably need cleaning. You can buy expanding foam cleaner which will fit up the whole thing and disinfect it.
There is a common oil leak from the cam cover plate. Small bits of oil will drop on the manifold and burn, especially after revving it hard. But that won't be what the rotting smell is.
Ok I drove today with the ac on, and fans on full. The fans didn't sound or feel like they were blocked. So I'll see if the smell is back tomorrow.
It’ll take more than a single blast an it’s likely to need a new pollen filter and vent disinfection. AC should be on year round with these cars, there’s literally no reason not to have it on.
They won't be blocked, but the smell is usually caused by bacteria.
