- 26 Sep 2013
- West End, Southampton
I get those too even with 1180 in 3DMark, if the ambient is high enough. I haven't found any games that benefit from more than 1100MHz though. I can run 1150MHz all day if needed, but then ARK wigs out. Having said that ARK wigs out no matter my settings
Undervolt/OC/Balanced/Performance you name it ARK dies eventually. ******* woefully optimised game.
Yep. Benching I can do 1780/1180 which gives a monster score, but in games you won't see any noticeable and obvious increase in fps running the HBM flat out. As long as you can get around 1100mhz that's more than a big enough bump up from stock. I just game 1700/1100 with low volts keeping temps down around 40c on both core and mem.
