guys, wifes p3 switched off and wont switch on again...any ideas?
tried charging for a while and then hold power on long..nothing...
we r in cambodia on holiday so no google shop nearby
thanks
How are you pixel 3(XL) owners coping without the Notification LED? Do you use an app to simulate or do you just use AOD?
I'm a 2xl but owner and never use a notification light. Not sure this phone has one tbh. The aod is good and I always just use that. I found with other phones the notification light woke me up at night and didn't really give much information compared to aodHow are you pixel 3(XL) owners coping without the Notification LED? Do you use an app to simulate or do you just use AOD?
I really wanted this phone but seeing as most of you guys have issues its pretty damn bad tbh that you need to be exchanging it. I am waiting to see how the s10+ turns out.
P2XL does have one, turn it on in the settings.I'm a 2xl but owner and never use a notification light. Not sure this phone has one tbh. The aod is good and I always just use that. I found with other phones the notification light woke me up at night and didn't really give much information compared to aod
not wet...Did it get wet ? My p2xl did that. I left it on charge for 12 hours and then it came back on.
Not sure what else you can do. What was happening when it switched off or did battery die and it turned off ?
7hrs SoT today on a Pixel 3 XL with 10% battery to go.
Decent![]()
What would be the android alternatives atm to this phone?
