I'm starting to buy PC parts for the first time and really need some advice or tips on what to build as I'm really not good at this. So far I've decided on the following:
CPU i7 8700k, MOBO Asrock Z370 taichi, COOLER Be Quiet Dark Rock 4, GPU 1080ti (not sure which brand though considering EVGA ftw), RAM Corsair Vengeance RGB Pro 16GB ddr4 (which i have already bought), STORAGE Crucial MX500 1TB (Which ive already bought), Samsung 860 EVO 1 TB M.2, TOSHIBA P300 3TB 7200rpm HDD, CASE Fractals R6 Design. Need a blu ray writer as i have games amd blu rays I'd like to watch/ play. No idea which psu i should buy.
I have also noticed that the i7 9700k is few £ cheaper than the i7 8700k. Is it worth getting it or should I stick to the original cpu I was looking at. If not which motherboard should i get? I would like something high end. Also i've noticed that the 1080ti is hard to get so are the rtx 2080 and rtx 2080ti worth a look? The maximum i want to spend is £3000 which includes a monitor (don't know which one to buy) and peripherals. Aside from 4k gaming I will be using Photoshop, perhaps GIMP and blender. Any help would be great.
