First time PC build help (£3000 budget)
yes but the point im making is that instead of a 1TB HDD you can get a 1TB Sata SSD instead if you can afford it. For the bootup you can use a NvME SSD thats ~500gb
I get what you're saying. In my op the plan was to get a Nvme ssd which I intend to do it will probably be smaller now (500gb) instead of 1tb. I already have a 1tb ssd and I'm getting hdd on top of that as extra storage and honestly to avoid having to add more storage down the line.
Oh well in that case you're all set then
