- 6 Sep 2016
Need a avr
Center speaker
Rear speakers
Speaker and hdmi cable
Center speaker
Rear speakers
I moved the sub around and for where we sit to watch the TV, the best place is right of the TV, left facing. I would expect placing the sub in the corner nearest to the neighbor would be much worse for next door than at the opposite side of the room? I feel it already integrates in, not overpowering at all and I can't pinpoint the sub really
I've got the XXLS400 and it's awesome, though I probably need to get it set up correctly. I don't think I changed many of knob positions on the back but ran the Onkyo room calibration thing. I'm by no means an audiophile but it sounds good so I think the settings are somewhat correct. I will have to dig out how it is currently set up but there is some decent bass if needed. I was watching Saving Private Ryan a while back, the scene at the end where they are hiding in the shell craters and the Tiger tanks are approaching, DAMN that was generating some LFE! I will grab a picture of the pack of the sub and see if people think it's way out.
If you've used the auto set-up wizard on the Onkyo then it will have taken care of most of the setup for you. Your sub controls should be set as follows:
Volume - about 50%
Phase - 0 degrees
Crossover - Highest number / fully clockwise / LFE position (whichever is applicable)
Volume - about 50%
Phase - 0 degrees
TBH i'd set frequency to max and use your amp to set a crossover (unless it cant and i missed it). Also, are you sure you need to change the phase?Thanks, this is how it currently is:
Set up is as follows:
Onkyo TXNR676E
B&W 685 S2
B&W HTM61 S2
B&W M1 mk2
There are five dials, I wonder which one is massively out!!??
Also, does 'out' on the filter mean not in use?
Presume.sub xover is bypassed if not increase xover to max.
Don't need to use sub phase as avr does that.
What is your avr xover speaker size and lfe set to?
