Intel kills 10nm ?? oO
6 Jun 2008
Finland
Last time we heard about their 10nm process was rumors that they had fixed one of their issues.
That rumour about being close to solving one of the hurdles was actually in SemiAccurate. (for all its Intel bashing)
But now with 3 years and counting late from first "production starts in end 15" roadmap and apparently very little light in the end of tunnel, it wouldn't be wonder if Intel decided to do overhaul of goals.
They need some kind node shrink to keep making those monolithic server chips.
So even less ambitious shrink working in foreseeable future would be better, than current status quo of no sure idea when 10nm produces even desktop chips-situation.
They are going to use Principled Technologies to OC the report :D
No need to OC anything:
When you disable half of 14nm that makes 7nm...
10 Jul 2009
London
The problem is less ambitious shrink needs time if kick-started from today. I believe intel has several processes worked on in parallel, though with their brain dead management, there might be a chance they cut corners :D
Man of Honour
13 Oct 2006
It was Intel bashing in its own way though glorifying in them having to relax their design - which actually I don't think it correct - wish I understood the technical details enough to explain why - it is related to their approach to the lithography with the intention of making something on the limits of DUV which means they can't simply relax it.
Not so much cutting corners but by all reports progress on parallel capabilities have suffered as they've (re)directed resources to try and get 10nm working.
18 Oct 2002
West Midlands
I'm not sure how Intel are going to be able to justify wasting billions of more dollars if they cannot sort out the shortage in their current marketplace. They are going to be bleeding market share if not careful, and the amount of wasted time and resources that have gone in to 10nm development will only get bigger, unless they either come to market with huge amount of SKU's across all their segments in the next 18 months on 10nm then they are going to suffer. Whether that be running a 10nm that is more like a 12nm, or just dumping 10nm, keeping 14nm+++++++ going, and sorting the 7nm out by 2021-2023.
Either way, the shift from 14nm to 10nm needs to happen very, very fast, or not at all in order for Intel to be seen as taking its own market seriously by the people who actually own Intel stock.
10 Jul 2009
London
They will justify the same way they justified spending money on failed GPU attempts, or for contra-revenued mobile chips. remember, Intel is top of the pops when it comes to spinning things
4 Nov 2007
Scotland
But when you have so few atoms to work with on the < 10 nanometer scale, the engineering challenge becomes far greater. A single silicon atom has a diameter of 0.2nm, that's only five silicon atoms per nanometer not factoring spacing. Insane!
Caporegime
17 Feb 2006
Cornwall
Everything gets affordable once it hits mass usage/production and new tools being developed
Look at how many foundries there were on the leading edge years ago.
Look at how many there are now.
At some point nobody will be willing to invest the sums of money needed to move forwards.
At some point therefore progress will basically just stop, because nobody will be able to recoup the investment needed.
Have to say I'm a bit pessimistic. I think we're pretty much near the apex of what we will achieve; much like manned space exploration, the will to continue just won't be there in light of the staggering sums of money involved.
"10nm" is a marketing name only.
Much of the actual gate dimensions are far larger, like 70-80nm.
Which isn't to say it's not extremely impressive, regardless. Because of course it is.
Permabanned
2 Sep 2017
It isn't so much the money involved because money value is virtual, anyways and we can cover the costs. The problems are more political and the interests of some people.
Man of Honour
13 Oct 2006
As I said awhile back in response to that article - can't remember if it was here or another forum - a lot of what they said didn't make sense from a technical perspective when it came to 10nm and how you'd change it and as per the updated article it would be more likely they'd backport to 14nm rather than make changes to 10nm in the way claimed or move resources to 7nm.
Permabanned
2 Sep 2017
Either way intel are screwed for a couple of years, at least. 14nm architectures won't be so competitive, while 7nm is a distant prospect.
Man of Honour
13 Oct 2006
Probably not so distant - they've been working on getting EUV upto speed with 7nm - which seems to me to have been one of the stumbling blocks with their 10nm due to pushing the boundaries in certain areas closer to what you'd see on 7nm despite other areas being more relaxed.
semiaccurate.com said:
When we wrote the original piece there were four fabs slated to transition to 10nm. One of these has been backported to 14nm, something which can’t be undone in a time relevant to the 10nm transition. Two of the remaining fabs installed lots of EUV tools which are meant for the 7nm process, not the 10nm process. This effectively precludes these facilities from producing 10nm.
