And now its defaulting to the Samsung keyboard shortly after I set it to gboard... argh!
Any ideas?
Use the Samsung keyboard? It's not that bad.
I doubt know, I haven't changed keyboard yet, will try later.
Any ideas?
I use a lot of gifs to make my point is all.. I see your point and maybe I will but I'd rather not be forced to!
I agree you shouldn't be forced, The Samsung keyboard also has gifs if that helps, and a dark mode.
Well I managed to sort the notification thing, somehow it had gotten set back to hiding content so thats one thing, then gboard seems to be sticking since I closed all apps and rebooted.. I htink I probably had something open that was using samsung keyboard?
Anyway, I like it.. I just hate the fact I need to use the default icon set to get dark mode now.. Soooo close lol.
Well I've been using my note 9 with Pie and One UI since yesterday morning. Very impressed with the update but is it me or am I imagining it, over this morning and generally today the battery seems to have drained very quickly, I was down 25% by 10.30 and I wasn't using the phone any more than normal![]()
It feels as if the dpi has reduced or everything is bigger as part of the Pie update. I've got the smaller to larger slider in display setting set to smallest, yet seems like the status bar and maybe even the nav bar at the bottom of the screen and other elements in menus are larger.
