Caporegime
- 8 Jul 2003
- In a house
DDU Uninstall then re install driver
DDU fixed this, if anyone has the same problem - thanks @faceman123I'm having serious issues trying to get the adrenalin drivers to install.
I tried installing them on my r390 but the installer kept hanging on the detecting hardware screen.
So I tried installing my vega 64 - and it's still hanging on the detecting hardware screen.
Any ideas what's causing this?
@LoadsaMoney That TimmyJoe vid is quite interesting, didn't get the best out of the card either as with a 1850MHz core clock would have expected much higher Timespy and Firestrike results. ~8000 GPU score is close to 450pts below my Vega64 at ~50C with 1740MHz load in Timespy. Guess he didn't OC the memory.
https://www.3dmark.com/spy/4906893
CPU isn't tanking it that much. I'm on a ThreadRipper clocked lower and while I have more CPU score that's pure thread count. At 1850MHz under load that should be closer to 9000 than 8000, something really off with his test.Yep I've only ran timespy once ever and just used my daily 27/7 clocks of 1680/ 1145 @ 1050mv air cooled lol. GPU score of 8107... I'm betting his overclock isn't really stable but it's getting through the run. Pretty odd, unless his CPU is really tanking it?
Even if it's clickbait it's still worryingly low. Almost like those early driver revisions stating 1900MHz when it wasn't even close to that level of performance.I bet is a click bait. It's 1 point faster than my Vega 64 at 1704 mhz operational on those benchmarks.
I'm going to take the plunge and take advantage of the Sapphire Vega 64 Nitro+ deal upgrading from my R9 390.
My only concern is my current PSU is a Corsair CX750M. I've had this card for 6 years and its worked without a hitch. Does anyone have any experience running the Sapphire card with this PSU?
I would be planning to undervolt - but that's not really a long term solution if the PSU isn't up to the task without undervolting.
You won't be disappointed. I went from R9 290 OC to Vega64 it's a worthy upgrade.
Using Panos's settings you should pull 220-240W max which is in the same region as the R9 390.
Vega64 drinks a fair bit of juice but in the grand scheme of things, being an overclockers forum, since when does power draw really worry any of us here. You'll love your new 64 card. With the past 12-18 months worth of driver updates, it's now a fantastic gaming card, as are all 56 and 64 cards. I'll give it to AMD, they really do eek out every inch of performance from driver maturity.
If you're that worried about your PSU, sell it, along with the 3 free games you get with the Vega64 card, then use that cash to buy a new 850W PSU. Free PSU upgrade
I've had a 64 running for a while with my EVGA G2 750W and it ran fine. My PSU is only 2-3 years old though.
I guess I lost the silicon lottery hard if anything over 1500 reduces performance >_<That sounds like it might be related to your cards sweetspot as I mentioned in the post above.
So I've taken the plunge and went for the following:
- Sapphire Radeon RX VEGA 64 Nitro+ 8GB HBM2 PCI-Express Graphics Card
- and to power it: EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply
Can't wait to get it all hooked up this weekend!
