I thought it has to be used in the top PCIe slot? This is not true? Are there any disadvantages to using the second or third slot as my MOBO only has three? And currently the bottom one would not be an option because the PSU wouldn't give it enough clearance. This will change I think when my new case gets here very soon for better air flow etc.
Will do. But my R9 390 has and had zero problems for 4 years in that slot. Should I still test it?The top one is usually the fastest, yes, but it could be damaged/faulty. If you have others available then test it in them to rule it out.
Everything is stock but I'm constantly getting hard reboots in DOOM 2016, I've DDU drivers and not even enabled WattMan (fresh install of Win 10 1809) and 19.1.2 Adrenalin drivers:
but after the reboot I get:
I'm not sure how WattMan settings have been restored when it's not even enabled!
I have a feeling it'a actually something to do with the fresh install of Win10, something isn't getting loaded properly that's there if you're on an old install (maybe a driver or C++ redist pack or etc).
I'm tempted to find an older build of Win10 and try that.
So they are to control other pwm fans not the ones on the gpu itself?
Thanks @Panos - any idea which is default - to the right or left? cheersAs you see the card upside down in the case, to your left at the end of the board.
Thanks - I'll play with that. Mine was on performance.Right is performance left is normal.
It affects your speed when you select Power Save/Balanced/Turbo presets.
Saying that with the Nitro on custom overclock found more stable the "normal" switch.
Would DDU not get rid of all that sort of stuff?I had issues in the past mostly fixed by purging out programs like Afterburner when having a new GPU. Get rid of all them and profiles/settings before testing your AMD driver versions.
Thanks - I'll give it a go.The scene switch drops are due to Unigine's method of unloading and loading assets. Nothing to worry about. Though I'd try out Superposition over Heaven these days. Heaven is mighty old and rather bad as a perf reference for Vega.
My first play with wattman I have a nice quiet setting with P6,P7 at 1000mv, 1632,1672 - which gives around 1570-ish steady, in heaven.
Or if I up P7 to 1100 I get around 1615.
Memory at 1100, 1000mv.
The occasional drops I get in heaven when it changes scene - is that the software, or more tweaking required?
ps. I have it running in 4k
