**THE NVIDIA DRIVERS THREAD**
Caporegime
8 Jul 2003
In a house
v418.81 WHQL Drivers Released
Gaming Technology
Includes support for new GeForce RTX laptops, and delivers the optimum performance in Futuremark’s 3DMark Port Royal benchmark, which has just added a new feature test for NVIDIA Deep Learning Super Sampling (DLSS).
Added or updated the following SLI profiles
  • Anthem
  • Assetto Corsa Competizione - AFR enabled for Turing GPUs
  • Battlefleet Gothic: Armada 2 - AFR enabled for Turing GPUs
  • Life is strange Season 2 - AFR enabled for Turing GPUs
  • NBA 2K19 - AFR enabled for Turing GPUs
  • Space Hulk Tactics - AFR enabled for Turing GPU
Software Module Versions
  • nView - 149.34
  • HD Audio Driver - 1.3.38.13
  • NVIDIA PhysX System Software - 9.18.0907
  • GeForce Experience - 3.16.0.140
  • CUDA - 10.0
Fixed Issues in this Release
  • [Gamestream][OS HDR]: Stream is not set to launch in HDR despite having HDR
  • display attached to the PC and client. [2467526]
  • [GeForce Experience]: Share FPS overlay appears in the Twitter UWP app from the
  • Microsoft Store. [2465033]
  • [G-SYNC]: Flickering may occurs in games if G-SYNC is enabled. [2399845]
  • [G-SYNC]: With G-SYNC enabled, after hot-pugging a G-SYNC display and then a GSYNC Compatible display, the right half of the G-SYNC Compatible display may go blank. [200484819]
Man of Honour
20 Sep 2006
Did a reinstall of Windows as the installer service became corrupt somehow. Decided to use Shut up 10 and also the 'cleaned' drivers, working fine so far.
30 Dec 2011
Belfast
I can confirm these fix the issues where I had to turn my 4K Samsung U32E850 off and on again after loging into Windows from cold boot, or after returning from power saving mode.
Freesync is working on this monitor as intended.
28 Feb 2017
Sunderland, UK
Anyone have any ideas on the below, or am I being a complete idiot?
Purchased a MSI 2080 ti gaming x today. Updated BIOS to latest, DDU'd drivers and installed it. Tried installing 418.81 but it says it's not compatible with this version of windows. So I've just sat and updated windows
Still says the driver is not compatible.
Monitor running off mobo is working, monitor plugged into GPU is not. Lights on GPU are turned on and visible. Now i'm stuck. What am I missing?
Caporegime
17 Mar 2012
ARC-L1, Stanton System
GPU DOA?
Permabanned
31 Aug 2013
Scotland
What version of Windows are you running?
2 Nov 2003
I am getting random blanking screens with this driver with freesync enabled, gone back to the previous driver and all is well again. weird :rolleyes:
Benq EW3270U
20 Aug 2020
South Wales
Used DDU a long time ago in the past and it somehow messed up my Windows install where it just caused a repeated BSOD loop, thankfully system restore fixed it. This must have been a good few years ago though around the Windows 8 days and I never touched it since.
Unfortunately I had to use it today as for some reason even a clean driver install refused to remove and reinstall the current version NGX driver, removed and reinstalled everything else ok though. A long while back one of the hotfix drivers had the NGX driver 1.3.0 but every driver since then always had a lower driver version so it never got overwritten with the new one. Seemed DDU was the only way I could remove it and thankfully it did remove it and my system is still fine.
Personally I would only use DDU as a last resort once I know I backed up my system first just in case.
