Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Is that a new R9?
Yup. 2018 reissue.Is that a new R9?
Overdrives are best used on a slight crunch. In fact, some people use an OD to give a crunch then a distortion to give a thick lead sound.
Try setting your amp to a light gain and kick it in. You should be able to nail an AC/DC tone with any OD pedal in to a dirty amp.
Yup. 2018 reissue.
Actual model is Gibson Les Paul Standard 1959 True Historic VOS finish in Honey Lemon Fade
Try 5kthat must be £4K?!
That is the exactly model that id like too, so much mooola though.
Try 5k![]()
Yup. 2018 reissue.
Click on my sig... some videos on there from my build thread.Can you play?
I'm looking to buy what I'm going to call a sofa guitar! I want something cheap(ish) and small(ish) that can sit in my living room to be picked up and played randomly and be cheap enough that I don't mind my kids getting there grubby paws on it and it won't be the end of the world if I sit on it.
Currently looking at the ibanez AN60
https://www.gak.co.uk/en/ibanez-an6...VBLTtCh19IgvbEAQYASABEgKLHPD_BwE&gclsrc=aw.ds
and the recording king eps-7-ta
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/192293303866
Anyone got an opinion on either of these or something else I should look at in the price range?
Try 5k![]()
The same can be said for anything?One wonders how better timber, extra attention to detail and hand ageing/finishing can justify Gibson charging an
extra £3600 for a retro Les Paul.
Whether it sounds or plays £3600 better than a run-of-the-mill standard LP is
surely open to much conjecture.
For the record, that is my dream colour LP too.
Although i do have a PRS SC58 which is unchambered, and arguably better built, just without the Gibson mojo![]()
