hi u can get it to work at 144hz . how acurate it as i dont know but going of the fps counter and refresh rate it does move up and down.
i could try and do a video with shadow play so someone could vertify who knows more than i do i got a explanation off a youtube video lol
BSD Gaming3 weeks ago
You can use 144hz also on G-Sync without setting freesync on. Go to settings systeem turn DP2 on , set freesync on. Go to graphics card set G- Sync on. Go back to settings systeem. Set 4K 144HZ on DP2. After you get back screen on the monitor go back to settings systeem. Set DP1 on. Go back to graphics card. Now you can see that you have G-Sync 4K - 144 Hz.
totallydubbedHD3 weeks ago
That doesn't sound right
@totallydubbedHD What can I say. My G-Sync is on and my resolution is 4K 144Hz on the settings Nvidia. My freesync is not on.
@BSD Gaming Very, very odd lol.
@totallydubbedHD Because you say " that doesn't sound right " I try it three times in a row and every time it works. From DP2 is my freesync on. I set 4k 144hz on. I chance DP2 to DP1. From that moment is DP1 closed. You can not go back to DP2. The only way is if you set 4k 144hz of. Freesync is now of but you have G sync on. I get every time notification that G-Sync is on from windows. I check it out on Nvidia Settings G-Sync is on and i have 4k 144hz. I can use also the VRB what does not work if freesync is on. The only thing is that i can not chance DP format. I have noticed after the update Nvidia that when i use shadowplay recording gameplay 4k 60fps and upload it to YouTube that the video after 8 hours stil 360p is. I don't know what the problem with that is. Before the update there was no problem.
Read more
@BSD Gaming sweet! Didn't work for me haha!
TRbeybifeyz2 weeks ago
@BSD Gaming just bought that beast. but my one is out of the box at dp1 (2 dp connected) / free sync off / gsync on / 144hz is on osd monitor and on nvidia control panel. so i dont get why you switch to p2 and back to p1?
BSD Gaming2 weeks ago
@TRbeybifeyz Otherwise I can not chance to 144hz if I stay on dp2. I have only 144hz on dp1. dp2 max 120hz. So don't set HDR on or you have 120hz and G-Sync of.
@BSD Gaming strange, despite i have 2 dp's connected. the monitor menu showing me at the input only dp1 and not dp2 . when i swipe in the input options, i only see dp 1 / hdmi 1 / hdmi 2. seems either i do something terrible wrong or every user has a different experience. i am totally lost here.
@TRbeybifeyz No no that is good. Dp2 is locked together with Dp1. That is why you don't see Dp2 in settings. That is why you have now 144hz with G- Sync. Under imput options you can find 4K 144hz & that is on. When that is of you have DP1 & DP2 under imput settings. But don't do that! Your settings are good
@BSD Gaming today i turned on the hdr to check and noted that my gsync option in nvidia menu dissappered. i turned off hdr and resetted everything but gsync didnt come back. any ideas?
@TRbeybifeyz I warned you. Now start the process. On settings ACER see that 4K 144Hz is of. If that is okay set freesync on & imput DP2 on. After that you get normal a message from nvidia that G-Sync is on. Go to Nvidia settings. Check or the G-Sync is on and that it is 120hz . When that is okay. Go to settings and set 4K 144Hz on ONLY IN DP2. After that you get again from Nvidia a message that G-Sync is on. Now the final thing that you have to do. From DP2 you go back to DP1. After that DP2 is locked with DP1 together. Now you have normaal back 144hz with G-Sync.
@BSD Gaming thank you so much for trying to help. its not nice from acer not to guide users on this issue. anyway, i followed your steps, i am back at dp1 and have gysync on but only getting 120hz. i hope i wont throw the monitor out of the window at the end. what i am doing wrong?
one sec, i restarted my pc. all ok now. its back to 144 hz with gsync on! i hope acer will hear you. they should contact you and thank you personally. anycase m8, thank you very much for the great help!
@TRbeybifeyzYour welcome . I'm happy for you that it works again Stay of the HDR OF now. It's not worth it. You can always make me happy with a sub on my channel if you like.
