Sorry, I've looked at several reviews and none give Arctic 33 a performance rating of better than mediocre at best. We need to keep in mind these review sites depend on companies giving them free samples to test, so very few review sites say a cooler is bad. We need interpret what is called 'average' as actually being poor .. becuase they almost never give a poor rating. Also keep in mind reviews done in a case system using room air temp are extremely inaccurate. Reason being the air temp into cooler is not the same as room. All they give us is how the review system performs with different coolers. I don't know about you but I don't care how their test systems performs with different coolers. I only what to know how well each cooler performs against other coolers. To do that we at lest have to be monitoring/recording the air temp into cooler and CPU temp at same time, then assuming the air temp into cooler is similar (+/-2c) use them to a delta temp to compare cooler performance.
Yeah, NH-U12S is a good little cooler .. overpriced compared to others with similar or better performance like Matterhorn Pure I suggested above. Matterhorn is better than H7 which is better than Hyper 212 which is better than Arctic 33.
