- 25 Nov 2015
Switching the bios switch left, towards the rear of the case, is power saver mode, to the right, towards front of the case is performance.For whatever reason, I didn't have the latest Radeon drivers installed, despite downloading from the website. I did manage to get the card running a bit cooler and quieter with the old drivers, but with the new ones the fans have finally stopped spinning.
With the Pulse card, I've located the bios switch, but it doesn't mention in the manual which position is which? Can anyone shed some light?
I'm also running a 520W Seasonic 80+ Bronze PSU (gpu impulse buy, lol). I've seen conflicting reports about PSU sizes, but for now I would prefer to not upgrade. Am I risking my system?
I'm not planning on doing anything but undervolting it for the time being to be honest.
Try both - but you might find powersave better for you. (I find it gives better min fps for not much performance hit)
Try P6 and P7 @ 1000 and 1050mv, as mentioned above.
Push the power slider to +50%.
Run heaven in windowed mode - it'll crash if it doesn't like the settings.
You'll only know if your PSU is good enough by trying it - can't see it damaging your system - the Vega card would probably crash first, it's full of sensors.
A good PSU though (eg superflower, EVGA) will form the backbone of your system for years to come.
