Caporegime
- 18 Oct 2002
I'll check mine later @greatash and see if it's doing the same. Don't think it is though, idle temp seems about right.
First of all, even an RX 480 will trump anything a PS4 Pro can do (let alone the base version)...
This is 100% true, I tried playing FFXV over steam link on a 2500k and an rx480 (4gb) and it loaded faster, played smoother and just looked better than the PS4, and that was going over a powerline ethernet from the PC and wireless to the steam link! Going to have to re-purpose to a living room game box when my 56 gets here for the main pc hopefully today, then I have to start looking at all this undervolting nonsense....![]()
Somone played Assassins Creed Odyssey on 1440p ? (2560x1440)
Would be interested how many FPS you can get with Vega56![]()
@Zernath
I´m interested.. sure
@dante6491
I have an i5 4670k@4,2Ghz.
I know.. AC needs much CPU Power.
Did you play on High or mixed settings ?
My Sapphire Pulse is running @950 Memory 910mV / P6 1547 920mV / P7 1622 940mV
Anyone else tried playing division 2 with overclock? My game crashed other day which seemed strange since I can play bf5 for hours on same setting.
I crashed a few times playing Overwatch actually.Anyone else tried playing division 2 with overclock? My game crashed other day which seemed strange since I can play bf5 for hours on same setting.
It seems to have major issues with DX12, did you have it enabled?
No I'm win7 so dx11
Okay, so at 1440p with the Very High preset, I was seeing between 50-60 frames per second, as I suspected would be the case. It rarely dipped below 50, and the overall experience was very smooth. Very High is the second highest preset option, so that's rather impressive results in my opinion, especially for such a demanding game.
I'm running the MSI Vega 56 Air Boost OC, and haven't changed the stock values yet (although I do plan to in the near future), so with your overclock I would expect even better results.
Edit: Native 4K at 40 frames per second is possible with some tweaks to graphical options, particularly AA to low, shadows to high, and clutter to high. So the Vega 56 seems very capable, considering it isn't really a card aimed at 4K gaming, and I'm sure I could squeeze a little bit more out of it if I tweaked further.
Thank youSounds good .. with some OC/UV there is a good chance to get the 60FPS permanent
No problem, it's a fun game, so testing this wasn't a chore. You'll definitely be able to get 60 with some OC/UV, I wasn't too far off it being a stable 60, and that's without touching MSI's stock settings.
I'm really happy with this card, the fact that I can get decent 4K performance out of it really made the asking price an even better deal!
