- 17 Sep 2006
- Gloucestershire
Is there a common misconception that snow foaming is an alternative to a proper physical wash then?
Is there a common misconception that snow foaming is an alternative to a proper physical wash then?![]()
Very poeticI like the think of snow foam as soaking the dishes. It softens and loosens the dirt, so when you rinse most comes off. You still need to clean though![]()
Just put an order in for some Gyeon products, coming in the next couple days.
Gyeon Q²M Wet Coat
Gyeon Q²M Bathe Plus
Gyeon Q²M Leather Coat
Gyeon Q²M Leather Cleaner
Gyeon Q²M Leather Cleaning Brush
Just got hold of some chemical guys honeydew and the watermelon snow foam. Strangely found it on great yarmouth market there is a guy who specialises in american products got two of the 473ml bottles for 18 quid
Yeah even so though think I'll use his website to avoid having to brave GYThat's not too bad, almost makes the thought of visiting GY acceptable! I'm sure Wilco had some chemical guys stuff, but i may be mixing it up with poor boys come to think of it...
I've used glass cleaners but never thought to use normal car wax on the windscreen. Might try some collinite on it
I would never put any wax on the outside of the windscreen. The wipers will smear it and probably make it worse. Use a proper glass sealant if you want... :O my old Mazda had something on its windscreen, took me hours of polishing to get it off, was horrible.
I've got something on the Porsche that I just cannot get rid of. It's persisted in the areas where the wipers only cover once but has gone in the portion that both blades cover.
I've tried every glass cleaner going, clay, razor blade. Nothing will shift it.
