- 30 Sep 2005
Does anyone know how much a years warranty is for an Audi A4? Assume there is room for negotiating discounts?
Cheers!!
Cheers!!
If you go to the Audi website and enter the car details, it will give you some cost options.
https://www.audi.co.uk/owners-area/warranty.html
Now for the down side:
Heater box was faulty from new so wouldn't demist, necessitating a replacement. Surprisingly they didn't introduce any trim rattles as it's a dash out job. 2 days at the dealers for that.
Rear crank seal appears to have failed resulting in an undertray full of oil and a nice pool on the drive. Currently waiting for the diagnosis to be confirmed by them dropping the gearbox out and then if so for parts to arrive to fix.
Not bad for 2 months and 1700 miles of ownership! On the plus side, the dealer is handling things well, which you'd hope being warranty work on a very new car, and I'm driving around in a rather nice A6, it feels like a boat in comparison.
Just keeping fingers crossed for this being the last thing so I don't stop enjoying the car.
my god that 5-pot screams!
RS3? Decent upgrade! 8P or 8V?Indeed, I’ll be picking up my Golf R replacement in a week or so![]()
Well jealous2016 8V RS3![]()
Have you had the air con serviced regularly? If not it could be just the case that the gas has got low. Charge for refilling it could be up to £65 depending where you go. They should put a dye in it so that any leaks can be detected with a ultra violet lamp....A/C has stopped working in my A3 8v, you press the button and the light doesn't stay on. I have an ODBEleven and it is showing the code b10abf0, which is apparently the coolant pressure.
Anyone know what it might cost to fix? Been reading around and could be anything from holes in the condenser to a cracked pipe.
Question for the 2017-2019 Audi S3 Owners - Is the steering as bad as they say it is? I'm looking at them to potentially transition to from a GT86 which already has quite a raw feeling but keep hearing the steering makes it a "boring" car. (Transferring due to change in job role and need the practicality of something bigger so an S3 is the choice)
