- 5 Sep 2011
- Surrey
@Silent_Scone
What settings are you running in bios to let your vcore and clocks drop?
btw I'm running pretty similar setting for 24/7 on my RAM also but at 2T. The GB Auros Pro boards aren't great at RAM OC.
The key factor is in the subs at that frequency, really (and 1T). Adaptive voltage and a loadline of 6. Most (if not all) of the 4 DIMM boards will top out at 3800 for 1T.
Is that 1.3v load or vcore ? 91c is a bit toasty, but not critical, as you wouldn't be putting so much stress on the chip day to day I wouldn't think, are you using an AVX offset, you could always set a 2 or 3 offset to bring temps down when the processor utilises these instructions. JAT.Is 5.1ghz @1.3v ok for 24/7? It passes realbench 1 hour with a max temp of 91c
1.3v vcore according to cpuz I think it loads at about 1.325, no AVX ofset at the minuteIs that 1.3v load or vcore ? 91c is a bit toasty, but not critical, as you wouldn't be putting so much stress on the chip day to day I wouldn't think, are you using an AVX offset, you could always set a 2 or 3 offset to bring temps down when the processor utilises these instructions. JAT.
Looks like you are getting higher voltages under load, better off the other way round, what LLC are you running ?1.3v vcore according to cpuz I think it loads at about 1.325, no AVX ofset at the minute
You are using a 9900K I take it, your sig says AMD ?Looks like you are getting higher voltages under load, better off the other way round, what LLC are you running ?
Yes mate just switched overYou are using a 9900K I take it, your sig says AMD ?
Using the gigabyte Aorus Master and LLP set to turbo, also using 32gb 3200mhz 2x8gb sticksLooks like you are getting higher voltages under load, better off the other way round, what LLC are you running ?
Turbo is obviously causing overshoot under load, try the next one down, cant remember what its called on Giga boards, not used Giga since x99 days. You will probably have to compensate with a slightly higher vcore to allow for vdroop.Using the gigabyte Aorus Master and LLP set to turbo, also using 32gb 3200mhz 2x8gb sticks
Don't know if this guide is any good for you.Yes mate just switched over
The two main tools are the der8auer or Rockitcool ones. Put the 9900k in the tool and apply pressure to one side, then turn the 9900k and apply pressure to the other side. You don't hear a pop like you would with the 8700k or previous CPUs due to the solder, but you'll see the IHS begin to move.What is the best tool to delid the 9900k?
Mind running Geekbench 3? would like to see your mem score. I'm getting 7042.
My timings are below. Let me know if have any recommendations to tune them further.
On my board changing "tWTR_S/L" don't get trained and stay at 8/17 regardless of what I put in there![]()
If I lower my cache from 4700mhz will I get more out of my core frequency or lower volts/temps?
