- 21 Oct 2012
What is the cooling like on this case? as I can see it's coming from the side instead of the front
Most configs I have seen tend to have intake bottom and side, with exhaust up top. If the GPU is mounted normally, I'd imagine that the temps for that would be good as cool air would be going directly to it. CPU wise who knows, esp as there is not rear exhaust, but I've seen a real range from that point of view with just anecdotal evidence in youtube etc. Seen OC 8700ks go to 70 tops on AIO and I would imagine full loops to be cool regardless.What is the cooling like on this case? as I can see it's coming from the side instead of the front
no the fans face outwards. Lian Li and Cooler Master have vertical brackets that fit. Just give builds a google and you will find loads of builds with something like that. Does mean that you will loose the ability to use the other PCI/PCIe slots though, so bear that in mindI'm not sure how i'll configure it yet, exhaust up top would make sense, as the heat should help itself up there. I might take some pics and stick them up here once i've built it and tested a bit. I'm interested in the vertical mount GPU configuration, but wouldn't that face the fans on my 1080ti to the motherboard?
Mine has shipped! All praise OCUK![]()
Mines ready for collection. Oh the beaut of living just round the corner from OCUK
Well, its turned up safe and sound. If only I wasn't stuck here at work!!!
Is that yours, Orbital?
Edit - nvm, i answered my own question and found it![]()
It's an asus maximus hero viii board, the rgb control unit attaches to the USB header at the bottom (near the front panel connectors)
