Mate, on your spec how do you find Lightroom performance? Noticeable improvement over your previous build?
Having a play with OCing the 9700K. Doesn't look too promising TBH. 5Ghz on all cores requires 1.3vcore with LLC level 2 which sees vcore hit 1.47 when doing a cinebench run.
worth having a look with asrock forums, no the aorus doesn;t pull that much even with MCE on - might have to increase LLC levels and voltage slightly higher to combat spikes
key thing is voltage when doing workloads and not benchmarks
have exhaust ! little rpm but should help
Would a good starting point be to set something like 1.4v and a high LLC to see if this is stable and helps with spikes?
Fixed it. Updated the BIOS to version 1.6 which was released today actually. Within BIOS there is now a Voltage Mode - Extreme or Normal. I presume previously it was always on Extreme meaning it would ramp voltages more. Now 5Ghz on all cores running Cinebench I'm hitting 1.364 max voltage.
Temps sit around 66-70 which seems good.
SQUEEEEEEEEEEEEEEEEEEEEEEEEZE!I may see if 5.1 runs on this voltage, but not too bothered about squeezing every ounce of performance out of it.
My RMA was processed today for the Kraken. The good news is that they agree it's not good, the bad-ish new is they can only give me store credit (FYI I didn't order from OcUK). So I've used the credit to buy another Samsung 1TB EVO 860, I'm sure it will come in handy.
store credit... it was within 14/30 days right ?
Should be fine with your monitor - the board has both DP and HDMI.Presume I can run my monitor off the 9700K iGPU while the 2060 is off for RMA?
