14 Mar 2019 at 09:27 #21 FishLicker FishLicker Associate Joined 17 Jan 2015 Posts 1,547 james.miller said: Enough time for Google to iron out the bugs Click to expand... A little optimistic, no?
14 Mar 2019 at 09:36 #22 V_R V_R Soldato OP Joined 17 Jan 2007 Posts 9,984 Location UK Matteysan said: There isn't a toggle for it in this beta. But if you have night mode enabled before you update to the beta it will enable it. Click to expand... This is correct. I actually turned off dark mode before installing the beta as I read it is quite buggy, especially in the Photos app. Edit: OP updated with detail of how to join. As Google+ is dead, Google have an official subreddit for bugs etc here: https://www.reddit.com/r/android_beta/ Last edited: 14 Mar 2019
14 Mar 2019 at 09:47 #23 glenimp617 glenimp617 Soldato Joined 30 Sep 2005 Posts 16,892 Matteysan said: All done here too, Love the actual dark mode, Accent colours finally here Developer options > theming > accent colours. Click to expand... Knowing Google, that's where they'll keep it
14 Mar 2019 at 10:54 #24 james.miller james.miller Soldato Joined 17 Aug 2003 Posts 20,168 Location Woburn Sand Dunes FishLicker said: A little optimistic, no? Click to expand... Touché
14 Mar 2019 at 13:06 #25 Matteysan Matteysan Soldato Joined 15 Nov 2004 Posts 5,997 Location Telford TheOracle said: Knowing Google, that's where they'll keep it Click to expand... That or they'll remove it claiming material design 3 is coming.
14 Mar 2019 at 19:27 #27 V_R V_R Soldato OP Joined 17 Jan 2007 Posts 9,984 Location UK Heads up if you're a Santander customer, their online banking app thinks your device is rooted if you're running the Q beta as I've just found out. Gpay works though.
14 Mar 2019 at 19:35 #28 Dangerous Dangerous Soldato Joined 18 Oct 2002 Posts 21,840 Location Nordschleife NatWest works however Halifax doesn't FYI
15 Mar 2019 at 06:45 #29 uvarvu uvarvu Soldato Joined 29 Apr 2004 Posts 5,097 Location Bath Starling is also broken. Curve is okay.
15 Mar 2019 at 08:12 #30 xb8browney xb8browney Soldato Joined 19 May 2005 Posts 6,897 Any one had issues with WhatsApp not backing up anymore?
15 Mar 2019 at 08:49 #31 Foyman Foyman Associate Joined 9 Nov 2003 Posts 429 Location nr Stoke xb8browney said: Any one had issues with WhatsApp not backing up anymore? Click to expand... Yes, gets to 100% but never finishes so I have to cancel it.
15 Mar 2019 at 09:20 #32 V_R V_R Soldato OP Joined 17 Jan 2007 Posts 9,984 Location UK Ah yes I saw that mentioned on r/Android_beta. Thats a bugger if you want to wipe and go back to stock. Here's a list taken from the above subreddit of apps with issues. https://www.reddit.com/r/android_beta/wiki/index
15 Mar 2019 at 09:24 #33 V_R V_R Soldato OP Joined 17 Jan 2007 Posts 9,984 Location UK I've updated the OP with some links etc for anyone new looking at enrolling into the beta.
15 Mar 2019 at 12:16 #34 V_R V_R Soldato OP Joined 17 Jan 2007 Posts 9,984 Location UK Tip: go to app settings > default apps > roles. I had a good few in there that were blank, including call blocking. I've reset the apps back and now I have the option to block calls again.
3 Apr 2019 at 22:06 #35 uvarvu uvarvu Soldato Joined 29 Apr 2004 Posts 5,097 Location Bath Second beta is up. It doesn't feel as stable as the first. All of the gesture navigation has gone out of the window. https://www.theverge.com/2019/4/3/1...ldable-phones-bubbles-chat-heads-multitasking
3 Apr 2019 at 22:56 #36 V_R V_R Soldato OP Joined 17 Jan 2007 Posts 9,984 Location UK Just updating from B1 now. Will see how it is, worst case I'll go back to stock.
3 Apr 2019 at 22:59 #37 xb8browney xb8browney Soldato Joined 19 May 2005 Posts 6,897 Took ages to boot
4 Apr 2019 at 13:27 #38 Matteysan Matteysan Soldato Joined 15 Nov 2004 Posts 5,997 Location Telford Mine seems to be smoother than beta 1, chrome was janky before but now it's smooth when scrolling. Hate the way they've changed the swipe away for notifications. I like the ambient display setup now though.
10 Apr 2019 at 20:47 #39 V_R V_R Soldato OP Joined 17 Jan 2007 Posts 9,984 Location UK Just downloading a 19mb patch to beta 2.
10 Apr 2019 at 20:53 #40 Dangerous Dangerous Soldato Joined 18 Oct 2002 Posts 21,840 Location Nordschleife V_R said: Just downloading a 19mb patch to beta 2. Click to expand... That's odd they don't normally release mid month updates, I've checked and also got the update.
