My Xbox One X was bought in October 2018 from Amazon and over the past ten days it has being doing some odd things.
Initially the first issue was an error message when playing Fallout 4 about save games issues and I was prompted to delete saves from the console and re-sync from the cloud, lost most of my progress in the game as a result. Also had some HDMI dropouts and tearing in Fallout 4 as well, but nothing else. The save game issue happened once in RDR2, but every other issue was in FO only
Then the dashboard starting being super slow and laggy.
I did a factory reset, but just the OS and somewhere along the lines I removed the FO disc and when I tried it again I got the corrupt disc message. This was the only game I own on disc, so I bought Metro Exodus today (Tesco vouchers I've been saving), I got the same corrupt message with that as well.
Figuring it was completely fubar I figured I may as well do a full reset in preparation for it going away to MS once it has finished I thought I'd try Metro one last time, and it is perfectly installing right now.
Not sure what to do now, I'll try installing FO once Metro has finished - I bet it works now.
Should I just bite the bullet and simply send it of for service?
If so the RMA I completed last night was all about the save game issues, the disc drive issue (if there still is one) only came to light afterwards so it isn't mentioned, can you go back in edit the info you provided?
Had a PS4 from launch and a Pro from its launch, both perfect, bit pants given this is only 6 months old.
Ta
