- 9 May 2012
- South Wales
cases are becoming more and more extravegant now and are going back to that chunky style too i find
I feel like i should have seen this ages ago, this build fills me with ideas for my own. Nice 1!
And congrats on the news about your third!
Image may be a bit big until I can edit sorry
Slapped on a vertical mount kit from Cooler Master
Gonna have to rethink the RGB PCIe cables a little bit :/
https://imgur.com/a/36fcZAp
thats better, great work mate
or wait for the ROG version to do it ...That is one colourful pc!
I'm really liking the vertical mount, esp with being able to squeeze the fans in below. Is there any cutting needed to get it all in? I know there are a few versions of vertical mounts available so trying to figure out pros and cons.
Also congrats on the third. Not sure I could go back to the sleepless nights after 2 already. But they ARE the best things ever. Congrats.
Might be able to spruce spare MSI itx from a friend.. thinking either in the top or the backor wait for the ROG version to do it ...
Kids love it, I turn it off haha
No, the coolermaster has like a step up in it . As their cases and few others have SSD mounts on the PSU shroud so designed to go over it
And thanks![]()
No, the coolermaster has like a step up in it . As their cases and few others have SSD mounts on the PSU shroud so designed to go over it![]()
you notice much temp variance between vertical and horizontal? These are nicely set back, so should still have air in front of them, but would be good to know your thoughts on itAh great to know. Will stick it on the to buy listyou notice much temp variance between vertical and horizontal? These are nicely set back, so should still have air in front of them, but would be good to know your thoughts on it
Will make sure to bear it all in mind. I just have standard height RAM for now, which is good, as the FTW3 I have is one of the widest. Any more plans for the build you thinking to add in?
Stunning. Can you reconfirm what the fan set up now is? Top Exhaust, Side Intake etc.... (obviously I guessed those)
