- 11 Jan 2007
- *̡̡ı ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡
Interesting video on creating a single player build:
remove the 12x scope or replace it with some other sites or scope, no more zoom or view resetting. Takes a little while to get used to but it's very good
and yeah, lmg is a favourite too![]()
@chroniclard do you have the in game dof on? In td1 dof used to affect scope speed on sniper rifles and blur and its the same in td2. I ended up using a x8 scope for a while but in PVP i use a scope that doesn't zoom at all
Hi guys, created a clan OcUk on the ps4. Couldn't find one already to join
You can find a list of box locations online if you want to skip searching for them.I keep finding or getting keys but so far have only stumbled on one box that these keys opened, any advice on this guys?
you mis read my post I have the keys it is the boxes they open I am having trouble finding.look in underground areas and tunnels, there's one directly south of the white house close to where you start the game. There's usually a few of them down there (keys for each enemy faction) in what looks like a locker attached to the wall which you need to open.
Not sure if mentioned already but check the supply rooms at control points every 24 hours as they reset...I got two purple weapons yesterday from mine (M60 and Famas)
I was waiting on you and Nexus, it never happened lol
