Buying new 2080 or b grade 2080 ti
Well performance wise the 2080 is just a 1080 ti with -3gb vram and RT cores slapped on. Also the 1080 is 3 years old now. A £700+ card in 2018/19 should have more vram.
I bought the 2080 but I know it terms of what it is...it's a pretty bad purchase. I just wish I could wait longer for 7nm
I can't see that the triple fan B stock cards are duds. I'm sure even within 3 months if it was going to break you could break it with heavy clocking.
Does the manufacturer’s warranty still apply in these cases, even if the retailer only gives 90 days?
Your contract is with the retalier not the manufacturer and as you are not the original purchaser of the goods the manufacturer is almost certain to tell you to jog on.
Regardless of whatever warranty a retailer advertises you can go back to them for up to an absolute maximum of six years (5 in Scotland) after purchase with faulty goods. In the first six months the burden is on the retailer to show the goods were not inherently faulty at sale (ignoring any stated or obvious faults at point of sale) ... after six months it's on the purchaser to prove the goods were not satisfactory, as described, or lasted a 'reasonable' amount or time whilst having to discount that any end user misue was a factor (good luck with that if you are the purchaser of a GPU).
Not a lot of vendors offer warranty on used cards, but EVGA certainly do. It'll be backdated to when EVGA originally shipped the card out brand new though, rather than when you purchased it used.
Its hard to ignore the Radeon 7 for 2080 money, I'd look at that
