The Radeon VII Owners Thread
Has it changed it's overclock ability? If so what clocks were you gaming with before and after? Actual gaming though not Time spy & Firestrike etc.
I can happily game at 2000mhz 1200 memory with 1.14mv all day long, junction temp in doom which I just had a go at was 54c junction, core temp 38c as for max clocks I don't know yet, but I managed 2100mhz on air and would imagine a little more on water.
I think you can do reg power mods in registry ect from a few posts back, but I don't want to get into that. my main reason for the water block is above, 2000mhz 1200 mem and not a throttle in sight.
Wow 1.14mv on air must be loud, I can't seem to overclock my core at all with games, I've been dropping the voltage though, I'll have to give it a try with higher volts to see what happens.
At stock clocks 1800mhz and 1000 mem I can undervolt to .940mv default on my card is 1.045mv. At 2000mhz core and 1200mhz mem I can go as low as 1.120mv but up it to be 1.140 and no problems in anything. I do find this wattman to change the standard defaults now and then but 9 out of 10 it defaults to 1.045mv
anyone tried after burner yet for clocking?
Yeah I have the most basic of power play reg mods, all it does is let's me do 50% power and the memory can go up to 1300.I didn't want to mess any more until I have a water block
I don't know anything about the reg mods, I just use whats in wattman. used to use afterburner with my titan, but I am not sure it works to well with the VII
That's what it does, changes wattman slightly to allow 1300mhz as the most not 1200 for the memory and +50% instead of 20
will have to have a look into the power tables then. these are my idle temps just surfing, and one thing I have noticed with this block is that it has a great flow rate.
18c 19c trust PB to put its banner right over the temps lol
