Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Yeah I posted about mine a few pages ago, after someone else recommended/talked about theirs - this was it:
500g 58mm Espresso Coffee Distributor Tool Macaron Coffee Leveler Tamper with Three Angled Slopes Non-slip Thread for 58mm Portafilter https://www.amazon.co.uk/dp/B0788M5HS9
Use it daily. Immeasurable value to me now, there's just no way I could ever be as consistent without it.
I don't see how the 2blade will be as stable and good at levelling ... on aliexpress/ebay (see earlier OCD discussion in this thread) more like £15 too.
I didn't finally sign-up, as my dosing/Rocky grinder, does dump a uniformly distributed charge, across pf, versus, the on demand grinders, with a narrower/chute delivery.
On the otherhand, was looking at some/a replacement Motta shot glass https://www.amazon.co.uk/gp/product/B074KHKHS6 to replace my borken blue Lavazza one,
Until I read up, I had not realised absence of glass espresso cups, is predominately because glass conducts heat too well versus ceramic ... the double walled ones are a bit delicate in the hand.
if it's clumped, at all, initially, it's more likely to pack it more densely in some areas with just 2
some have a grub screw, others rely on thread tightness too maintain depth
It is currently still on indiegogo, I was worried the price might go up more if it ends up at retailers. There was no options apart from the colour.
My biggest want was the low retention and it really is great, apparently it will also improve as the burrs are seasoned. I didn't think I'd be able to taste any difference but I can, even Lavazza beans taste good and my current Pact coffee has also taken a whole new level.
