Caporegime
- 9 Nov 2009
- Planet Earth
I should have thought about a Budget Intel ASRock, VRM heat sync still look's inferior, like they are trying to save money, the SOC doesn't have one at all.
They technically are 3 phase, yes, but current is still split across 6 Hi and Low Fet's and Chockes, because there are twice as many sets the Ampage is divided up between more components = less heat per component and that makes a huge difference.
74c is the higest i have ever seen them and that was overclocked during extensive stress testing, they are rated for 125 to 150c.
You can get the B450M Mortar for £80ish now and that has a solid VRM and good cooling so not sure why OcUK is selling them for so much. The ASRock boards also appear to at least implement properly finned heatsinks on their B450 boards.
Also WTF is the Ryzen 5 2600 costing £170 here?? Its £140 to £150 at most other places I looked at!!
