It would be great news but may I refer you to Utah:I will take that with a pinch of salt from there
But here's hoping
What is the advantages of the x570 with a 3000 ryzen over a x470?
Is there anything substantial for a gamer man like myself?
https://wccftech.com/amd-ryzen-3000-15-percent-ipc-uplift-4-5-ghz-x570-pcie-gen-4-40-lanes/
Heads up for those that haven't heard me say this.
First Gen engineering samples were a flop ! All be does received this thought the same, was truly aweful units and retail version was completely different , and hence all the bios tweaking and ram profiling .
I don't think AMD would do the same but also believe these chips wouldn't clock as low as this , guessing would be some of the first batch and Vendors are just as bad for leaking stuff (hence how videocardz get all their stuff from vendors a few days earlier then they should ) .
Personally hoping 5ghz is in site and 4.8ghz is the mainstream
The report states that the samples allegedly feature a 15% boost in terms of IPC which would be a good increase over existing Zen+ based parts that already lifted the IPC by 3% over Ryzen 1st Gen CPUs. It is also reported that the boost frequency for these samples is reported at up to 4.5 GHz which should scale better with higher core and higher TDP parts. It looks like AMD would make a serious focus on the efficiency of their 7nm processors while delivering a good boost in processor performance over the last generation parts.
What we know about XFR2 is that it boosts the clocks automatically, so I think there's a very high possibility that the WCCFTech linked IPC figures are contaminated by higher clocks that aren't being accounted for, especially so if your higher boost numbers are in effect.I was just coming in to drop that wccf leak, it is pretty close to what I expected, 200mhz increase on a new process but 15% IPC gain. That puts it at stock very close to a 9900k running at 4.9... If they achieve 4.6 or 4.7 boost then the IPC gain will see it beat out intel. That is without the increae from the better IMC, although it seems that the increase there is marginal.
