Maybe it was a press car or something. It is an odd spec.Yeah, it’s unusual isn’t it. No folding mirrors among all that spec either...!
Not with that reg. The other odd thing about it is that it wasn't registered until September, which was several months after the LCI. But it's a pre LCI car.
I thought the digital clocks were LCI only
Perhaps BMW had some spare stuff in the parts bin...
Pretty much your edit.I was about to mock you for 20 grands worth of pre facelift F10 but WOW @ the specification of that. Absolutely nuts!
Edit: Actually when you look at it, it seems to have loads of options you've like for 5 minutes and then never care about again (4 zone AC, heated rear seats, rear screens, rear blinds) but few of the really great ones to have - no cameras, for example. And being a pre LCI the high beam assist is sadly the basic pointless one![]()
Am I right in that I won't be able to renew the used approves warranty because it'll be over 10 years old next year?
https://usedcars.bmw.co.uk/vehicle/201903296418386?location=High Wycombe, UK"eref=b8d0bdfc-5599-4ff7-8cee-70b07c36d2bc
Tempted by this. No stereo upgrade, but I’ve got to accept very few cars will be perfect. I listen to a bit of Spotify and pod casts and have never felt my focus or base gen 1 Cayman stereo was lacking.
They are sending a video through as i can’t easily drive to see it.
Do you think it is worthwhile to upgrade? I quite like the live updates with Waze.Basic TMC is free, Realtime Traffic Information is 40 quid a year.
If you are expecting anywhere near waze quality traffic you will be unfortunately disappointedDo you think it is worthwhile to upgrade? I quite like the live updates with Waze.
d_ifIha9vA
Induction noise at it's finest.
