Finally got my buds, without first receiving an email from Samsung about them being shipped.
Now I need to decide; do I sell them, or give them a go and hope they sit properly in my ears?(I dont normally get on with these in-ear headphones, so not having high hopes for them).
Don't sit properly how? Too loose or too tight?
Did you try the different wing thingy sizes? I found they really worked and stopped me having to worry about the ear tip size beyond comfort
Oh man the buds are so much better than those, I see why you wouldn't want to use them now lol!
I've gone for it and opened the headphones.Im glad I did, you are right, they are nothing like the wired in-ear headphones that come with the s10 - they sit much better - and I've not even played around with the different tips/wings, the default one seems to sit fine. Thanks for recommending I try them out.
How's everyones factory fitted screen protector holding up, I'm just about ready to take mine off after getting it on launch.
Really showing some scratch marks. Anyone gone without yet and how is screen doing naked?
Just ordered a S10+ (international version for dual sim), any 'must do's' for the initial setup? Any bloatware that needs to go? Settings that are a must?
Furthermore, I always install swiftkey and NovaLauncher, anyone had issues with them on the S10's?
Had my S10+ for 5 days, installed swiftkey and NovaLauncher on it which I also had on my S7 and S9. No problems so far.
