Permabanned
- 23 Apr 2014
- Hertfordshire
Hype train picking up speed again!
I'm not on the hype train myself. It would take an official and clear statement from AMD to get me aboard. That said I do have faith in Zen 2. Zen+ has been awesome for me personally and I would expect nothing less from the next gen. AMD are certainly trying to push the envelope to the best of their R&D budget. Gotta give them props for trying and so fare succeeding in the CPU space.
I think the most you should be looking at is 4.5ghz and anything over will be a blessing.When do we expect pre orders to be available? If the 3700x hits 5GHz I'll be happy to place a pre-order.
Yep, 1600 MT/s IF with 3200 MT/s DDR4 might end up faster than 1000 MT/s IF with 4000 MT/s DDR4, for example. 2000 MT/s IF with 4000 MT/s DDR4 would be better than both but we don't know if IF or DDR controller can handle those speeds yet. I'm sure the benchmarkers are going to have a field day.![]()
Well there will clearly be more of a cross-over for those that just want the extra cores.However exciting the Ryzen 3000 kit is shaping up to be, I really don't understand where all the confusion and negativity regarding Threadripper comes from. Even at 16c/32t Ryzen is a totally different animal to TR and just won't step on its toes, so I don't buy RGT's statement that AMD bods are "confused" about how to market Threadripper.
Sure but that's not near the crossover point between the platforms in terms of cores so makes no difference.Tr is likely to be going 48 core though when the next version arrives later this year.
Before you had AM4 up to 8C and TR2 up to 32C so even ignoring the platform differences that's a massive difference in cores.
AM4 at up to 16C cuts that difference in half and will mean some sales for the lower end TR2 chips will be lost to AM4.
Will that be a significant loss? Time will tell.
TR still looks a very keen platform and the 3rd generation even more so even at 32C.
Very true, but so far most B-Die ram usually runs without issues.
This is a fantastic little tool to find them; a little database of known, and added B-Die dimms.
https://benzhaomin.github.io/bdiefinder/
I like to check that, the motherboard compatibility list; and then my fav retailers.
Then again, considering current Ryzen support speed prior to OC'ing is 2933Mhz; I hope the 3000 series ups that again also. Each steps makes it easier, and easier for new, and novice builders to get buy ram and slap in without fiddling in the BIOS, or looking up kits.
How are you finding it? I've heard good things about its performance-audibility considering it's a stock cooler.
Makes me wonder if Ryzen 3000 will improve OC'ing; as at the moment XFR kind renders it moot; unless you can get a decent all core clock similar to the XFR peak.
Yet the 1700X didn't eat into sales of the 1900X despite having the same core count. Threadripper is a completely different platform. If you only need cores and dual channel RAM then the new 12 and 16 core Ryzens will mean you don't need to jump onto TR, but TR gives you significantly more RAM capacity, ECC support as standard, a boat load more PCIe lanes for true multi GPU setups, full-speed NVMe and other lane-heavy kit like 10Gb Ethernet. And Ryzen's top 16c/32t CPU is TR's entry level CPU, with 48c/96t being the top end (purely because a 64c/128t TR with ECC RAM is more likely to eat in EPYC sales then a 16c/32t Ryzen eating into TR).Well there will clearly be more of a cross-over for those that just want the extra cores.
Which is a completely separate discussion. The context I have been discussing is people whose focus is on core count not the TR platform advantages.Yet the 1700X didn't eat into sales of the 1900X despite having the same core count.. .
I think the difference will be made up by volume sales on the AM4 platform
A 12C chip with 5GHz on all cores?I'd pre-order that.
