Hello all,
I have looked into this issue, talked with my RMA team and the guys at OCUK. We will always test and repair any item we are sent back under warranty . If it cannot be repaired the we will replace the card like for like or with the closest upgrade if there is no replacement anymore.
The card was repaired and a memory chip was replaced, the card was then tested and sent back. I can only presume the repair did not take as the report I have shows it was tested, we would normally then collect and replace the card. However OCUK have agreed to replace it from stock so we will work with them directly.
Sorry for the issue with the repair.
