Deleted member 66701
For guys who have bought the Quest over the Index, whats your reasoning?
No wires.
No wires.
You know, if the Valve Index or Rift S had wireless connectivity (and inside-out tracking) built-in I think I'd actually have considered buying them over the Quest.
I'll report back if it does get delivered early. Not holding my breath though![]()
VR Covers are out for the Quest
https://vrcover.com/oculus-quest/
£28del for the replacement interface and 2 different PU leather foams
£20del cotton cover x2 for the original foam
Yep, that's the price with UK delivery.They deliver to uk?
These videos are in French, but this shows why I am so excited for the Quest. Tetherless VR is the future!
Seems to be useless if using outside and any amount of sun
And!?
The quest will be great for vr with zero wires, easy fast set up and portability.
Not many would want to be waving around in a field in vr imo lol
The negative of it can't be played outside is like saying you can't use it underwater.
Its not claiming either![]()
Not need to be a hyperbolic monkey as will guarantee it will state it is not waterproof either on the packing or manual/disclaimer![]()
