If she mentions that the 16/32 part will be as fast as the 12/24 then I will wait. If not, I'll get the 12/24 (assuming its the "fastest").Confirmation of 8c/16t R5 and 12c/24t R7, with a mention that that a 16c/32t is coming too.
If they don't confirm a 16c/32t at the same time as everything else, they won't give clock speeds for it for the exact reason you've just given: if the 16c is fastest then people won't buy the 12c and just wait. That's lost sales.If she mentions that the 16/32 part will be as fast as the 12/24 then I will wait. If not, I'll get the 12/24 (assuming its the "fastest").
Not going to happen. No chance.5.0ghz on one of the sku's , even if it's the 8/16 , and I'm there with paypal in hand
AMD can't "confirm" the IPC boost and even if they did I wouldn't believe them. That's something that independent testers will verify, for a range of different tasks. I expect prices, cores, and clock speeds but sadly no availability yet.hopefully we get confirmed prices of each cpu. actual speed and ipc boost.
Personally if I were AMD I'd bang out a 16c/32t R9 anyway just to rub it in Intel's face. Intel don't have anything to counter the 12c SKUs, so to me there's not logic in "holding back" a 16c R9 just in case; release one at the same time as the others or don't release one at all.
How come? Do you have inside knowledge? Leaks have certainly suggested it’s possibke not that I think clock speed is the most important thingNot going to happen. No chance.
AMD are still playing catchup though, every time they have released a new chip, Intel have had something waiting to bang out very shortly afterwards.
Just every single thing I've read would suggest that 5Ghz is simply not possible. And no one has seen anything to suggest it is likely. All the "experts" have said you wont see 5Ghz. Stop expecting it to be.How come? Do you have inside knowledge? Leaks have certainly suggested it’s possible not that I think clock speed is the most important thing
Just not true. Not at all.
Ryzen released 8/16 consumer BEFORE Intel. Intel had to play catchup with the 9700k/9900k.
Intel are the ones playing catch-up. They have been for a few years now.
I know what you mean but Intel still hold the crown for single core performance, and as the entire industry hasn't really had to code for anything beyond 4c/8T (until Ryzen was launched) Intel were still regarded as the best chips by many.
8700K came out very shortly after Ryzen 1xxx
9700/9900K came out very soon after Ryzen 2xxx
I'm just saying imagine Ryzen 3xxx launching quickly followed by Intel 10xxx ? series
Then AMD immediately answering with a 16c/32T chip.
Its not surprising that most people are still on 2c/4c because most people don't have the money to be constantly upgrading their hardware, Ryzen (and subsequently 8700k/9700k) have only been released over the last 2 years. it takes a while for technology to seed itself, and until it is commonplace devs don't need to change anything.technically they still don't need to, look at Steam Hardware and 2 cores 4 threads, 4c/4t dominate by a huge margin! also 90% of games within the library don't run 4 cores well
but... ryzen 3000 just needs to get its speed up and internal tweaks and should be a 1080p powerhouse for cheaper hopefully
Im personally hoping 8 core ryzen smashes it out the part as the best gaming performance ... 12 and 16 cores are 90% useless to total gaming base currently - but least its giving intel a nice kicking![]()
Ah ok, no worries. I think AdoredTv were quoting 5Ghz but it’s sll speculation. Personally I don’t care to much about clock speed and think IPC is we’re its at. For me click speed is just about the willy wavingJust every single thing I've read would suggest that 5Ghz is simply not possible. And no one has seen anything to suggest it is likely. All the "experts" have said you wont see 5Ghz. Stop expecting it to be.
I'm guessing 4.3-4.6 Ghz boost with IPC increase.
5ghz was touted by many your not crazy. i think we more likely going to be at 4.5 tops. which is what im hoping for and intel ipc caught up. if its not im not interested as years old intel will just still be as quick so no point in upgrading.
