The OcUK Relationship Counselling and Hugs Thread
String whilst asleep is good, also can you compare to one of your fingers? If it's only a few sizes out then any decent jeweller would be able to resize with little issue.
Still doesn’t solve the the issue with ring size.
Those who have bought rings for their significant others, what size were they?
I kept slyly measuring my little finger against her ring finger then tried different sizes on my pinky till I found the one that went to the right part of my finger :p
Not gonna lie, I nailed it.
What did you do ?
Did you blow the house on 2 gucci belts?
I mean, you'll command the respect of the gentry but you will now be homeless.
Good work, good luck!
She said yes :cool:
