- 6 Jan 2013
- Rollergirl
Aorus ITX . either 7 or 8 vcore phases
I'm liking the look of that, and maybe EK will do a block to replace the fan?
Do you know if it has dual M.2 slots?
dont forget Samsung B-Die is no longer produced , will expect ram pricing for those IC to increase whiles others decrease
Yeah I suspect so...even Lisa mentioned that 3800x is the one gamers want...lol8 core from what i've been told , as you mention inter die as well as running the risk of one IMC being weaker then the other
right, changed mind from Aorus Pro to eithe elite or Ultra/Master now haha. not liking the looks
Good thing 3200Mhz is supported by motherboards easily now, should really help with b-die going away. Although if people want to pick something up now, here's the B-Die finder.
https://benzhaomin.github.io/bdiefinder/
And the 12 core will be £500+. LOLs.So it looks like the majority of leaks were simply BS, surprise surprise.
So far we've only been offered two 8 cores and one 12 core with the 12 core having a boost of 4.6 ghz
Yes, maybe after Cooper Lake, maybe not until Zen 3 depending on the market.16 core is coming later
Can't wait for the AMD defence force to now tell us how these prices are great.
PS5 is going to clean up. PC is just getting more expensive.
Thanks, AMD, Intel, nV.
Is there a good round up of currently known about X570 motherbpards anywhere? I was seriously considering MSI this time around but then remembered their BIOS updates are always in some proprietary packed EXE format, which means no injecting microcode updates down the line. With the current frequency of vulnerabilities that's a big minus for me.
Yeah and I/we had to put up with certain vocal AMD posters telling us how AMD would undercut Intel and make everything much cheaper.What can you buy from Intel at $500? Oh, an 8 core 16 thread
Well they didn't.
They matched Intel's prices at the mid-range. A £300 8-core mainstream AMD chip is the same price as an Intel 8-core mainstream chip. No cheaper at all.
Well they didn't.
