Permabanned
- 23 Apr 2014
- Hertfordshire
Yeah I won't be in a rush to upgrade 2700x though I will eventually. Looks a good time to upgrade for those on older platforms.
Is there a good round up of currently known about X570 motherbpards anywhere? I was seriously considering MSI this time around but then remembered their BIOS updates are always in some proprietary packed EXE format, which means no injecting microcode updates down the line. With the current frequency of vulnerabilities that's a big minus for me.
Yeah and I/we had to put up with certain vocal AMD posters telling us how AMD would undercut Intel and make everything much cheaper.
Well they didn't.
They matched Intel's prices at the mid-range. A £300 8-core mainstream AMD chip is the same price as an Intel 8-core mainstream chip. No cheaper at all.
I think you need to wait for benchmarks before claiming that AMD's self-confessed "entry level" 8 core part beats Intel's best 8-core part8 core 16 thread for $329 from AMD or
8 core 16 thread for $500 from Intel
I think that's a result, do you begrudge AMD making some money on their products?
Same. Time to retire the 3770k methinks.As a gamer and coming from a 3770k I'm looking at the 3700X vs 3800X, I think it depends about how well they perform in benchmarks and very curious to see how well they overclock. I think the 3700X will be adequate for my needs.
The company with the absolutely highest performing chips (without equal) always charges silly money for them. Both AMD and Intel do/did this.Intel
5960X $1000
6900K $1000
9900K $499
9700k $385 8/8
AMD
1800X $499
1700 $329
2700 £299
2700X $329
3700X $329
3900X $499 12/24
Yup, AMD matching Intel pricing the last few years....
Actual
AdoredTV
That 8 core part suddenly become a lot more expensive, nearly twice the price. A good reminder that all leaked information should be taken with a grain of salt. Although to be fair the specs are spot on, it looks like AMD decided to shift the whole product stack down near to launch.
Actual
AdoredTV
I imagine Nvidia did the same. Being too much of a fan can get you more than you bargained for.Yup AMD doing an nVidia. Enjoy your mid-range chips we've last-minute moved to occupy the high end SKUs, because lack of competition.Actual
AdoredTV
Shame was hoping for the leaked 3700x
Looks as if Intel are still going to have a clockspeed advantage then.
That's the 16 core and it tops out at 4.1 Ghz all core OC with big volts under water.
Concerned these zen 2 chips are going to top out at 4.2 to 4.3 all core OC. AMD needed that 15% IPC uptake badly.
So the 3700x is an 8/16 part running at 4.4ghz....
So the second coming Zen 2 won’t beat a 9900ks ?
Sad times...
IPC is better with AMD though, plus it uses less power.So the 3700x is an 8/16 part running at 4.4ghz....
Sad times...
We won't be seeing anything with decent uplift from Intel for another 2 years or so by the looks of things.Never thought I would say this with Zen2 but I might wait to see what Intel do in H2 2019.
