- 21 Oct 2009
Prices would be ok if the pound wasn’t a complete mess, but no doubt we’ll get almost 1 to 1 dollar to pound conversion which doesn’t half shaft us.
The 3800x nearly doubles the watt for 100mhz....looks like maybe these zen 2 chips will be at there limit in overcloking...
But it does mean the 3700X will be hitting thermal limits and throttling/not boosting anywhere near as much.That's not necissarily what the TDP means. Consider the fact that the higher clocked 12 core is also 105W it makes no sense that the 3800X will need all that thermal headroom. All it means is that the 3800X needs a bit more cooling than can be provided by a 65W heatsink, the actual TDP can be anything between 65-105, and is probably closer to the 65 than the 105.
Now to see the ITX Motherboards to be released![]()
Well I'm a bit underwhelmed. Prices are higher than expected and lack of big core options...
Not waded through in detail but I'm hoping the 12 core is released straight away and is faster in gaming.
Ahh, at what resolution? I'm at 4K 1080Ti SLI and apart from Arma 3 everything is GPU limited. It's only Arma 3 where I can really see room for improvement and I know 8086K/9900K really raceI went from a 5960X to a 8086K and I've seen large improvements, mainly due to the clock speed. I'm holding out for the 16 core.
Let's get a few things in perspective. Lisa only announced 3 SKU's this morning, the 3700x, 3800x and the 3900x. Obviously there will be more SKU's added as time moves on, there could be more SKU's added in a few weeks time.
As for prices, the 3800x is aimed to compete with the 9900K. A 9900K is priced at £500 from our hosts and the 3800x is priced at $399 (£314). Tell me what is so underwhelming ?
It won’t beat the 9900ks ....
a bit disingenuous to compare the prices like that when you know as well as i do that it'll be a 1:1 $ to £ conversion. 3800x is likely going to be £350-400 (more if there's retailer gouging).A 9900K is priced at £500 from our hosts and the 3800x is priced at $399 (£314).
3440*1440. It's not just gaming, general desktop performance is much better. It's the single core speed that makes the most difference I think especially on older games.Ahh, at what resolution? I'm at 4K 1080Ti SLI and apart from Arma 3 everything is GPU limited. It's only Arma 3 where I can really see room for improvement and I know 8086K/9900K really race
ahead in it but overall I'm struggling to see a need to upgrade. OK I've played Arma 3 over 5000 hours so it's really the only game I spend time on but I'm pretty sure I'll be limited by server speed
rather than CPU although one CPU core is consistently maxed/nearly 100% so I guess I would see an uplift.
Might change my gigabyte b450 microatx...got it as a stop gap - but would potentially like the cooling/nvme capability of the full fat boards.
Had my eye on the CH7 - so will probably go for CH8Entry Aorus x570 or Gaming X .
B550 have come to light but that's another post for another time![]()
Very interesting. Not sure what to make of it but here's my two cents:
Leaks were somewhat true, the clock speeds were accurate, but the lineup/processor name they belonged to was off. Seems as if AMD pushed down the apparent lineup by a step or 2. IPC gain was accurate in it being around 15%, but not sure if the clock speed will hit 5ghz, unless there are more chips to be released. I mean only 3 chips have been introduced, and all 3 were on the leaks (with different names) so its still entirely possible to see the other chips get released over time.
Not sure if we'll see a 16c mainstream chip yet as the Ryzen 9 seems to be the 12c and 7 is still 8c. Will need to wait on benchmarks and overclockimg ability to see the true performamce.
Pricing was the thing that was way off. In a way, the leaked prices did seem way off but it was to be expected that it was way too good to be true.
Now we just wait for other chips to be released by AMD and see the naming convention.
