- 26 Aug 2004
- South Wales
So that's even more worrying, if what you are saying is that their key Gaming CPU demonstration just showed that the 3800X could saturate a low end GPU as effectively as a 9900K in PUBG !?! Sure a 15% uplift in PUBG is great but we'd need to know the differential between that and the competition to know whether it was really meaningful.They were saying the CPU was removed as a bottleneck. We don't know what GPU they were using, but the game was effectively GPU bound. They also do show a 15% increase in PUBG over the 2700X even if you believe the benchmark was manipulate to show AMD in the best light.
Wonder when Digital Foundry will get their hands on a couple of chips for review.Well I'm not sure why you think its worrying. If the 3800X was beating the 9900K by a few frames, it might mean the gap is even larger with a more powerful GPU.
Wow pie eater, you really are pointlessly trying to pull apart the presentation with nothing more than guesses, which you keep changing and making ridiculous claims like it is "fake". To what end? Ryzen 2xxx were fantastic chips, and the extra IPC seems to have really lifted the single core perf substantially. This is shown time after time in the demos, consistently. If the the reviews come out and it isn't close to 15% on average then come back and say "I told you so" smugly. If the left is not as per there presentation then stock will tumble. .I really don't get the mentality of trying to find flaw so eagerly unless you have an agenda.
But you can't just have people flippantly saying the 3800X is probably on par with the 9900k for gaming. Doing so without the scientific results from the independent bench-marking community is nothing more than hearsay which will confuse the masses and discredit the enthusiast community for which we are all apart of.
Think about it... what if it's 5% slower on average? Then the statement is absolutely FALSE, what would we do then?
The 2700X was around 15% behind the 9900K in games, so unless AMD are lying about the 15% IPC uplift its quite reasonable to connect the dots that are there.
So theres no problem, look we all need to wait for independent reviews, but there is no reason to dismiss what is in plain sight.I mean you would think so.![]()
I think independent reviews will confirm around 9900K performance.
The key word here is probably which is clearly not intended as a scientific evaluation.But you can't just have people flippantly saying the 3800X is probably on par with the 9900k for gaming. Doing so without the scientific results from the independent bench-marking community is nothing more than hearsay which will confuse the masses and discredit the enthusiast community for which we are all apart of.
Worked it out to be a 1% quicker going by Anandtech's review of the 9900k.
GTA 5 - anandtech.com - 720p Low with GTX 1080 - October 2018
2700X - 148
9900k - 167
3800X - 169 (+14%)
Tried to do this with the other benches but they're all multiplayer so an absolute ******* to get a reliable bench outside using something like Userbench.
That's outdated, they should be using a 2080ti for those tests
Yeah I've already seen nvme single ssd been launched with 5Gb/s speed so four in raid 0 would give you 20Gb/s. Not that you need it. Having nvme ssd at 5Gb/s is nice enoughWhich doesn't need PCI-E 4.0, those are 3.0 speeds.
